38-1 code 121A
A slight variance in the schematics:  Schematic # 84 (code 121) shows a .05uf, part # 30-4177. What I have in there is a .002 @ 1000v. Oddly, this condenser (original, as it was buried under a bank of resistors, and looked untouched) is ALSO part # 30-4177(P), as is written on the condenser itself.   Question:  Since I didn't get a .002 @ 1000v (as there is no .002 on the schematics) when I got my new parts, should I stick the .05uf @ 630v in it, or just put the old .002 back in it- (it lays squarely at .002 on the meter)?  NOTE:  Out of 25 components I've changed so far, only 2 resistors have been out of tolerance, and only by about 30%. ALL other resistors have been within 10% tolerance... ALL capacitors have been dead on the money so far Icon_exclaim  I feel kind of foolish for "fixin' what aint broke", but I know all these should be changed, for safety's sake.  Icon_mrgreen
38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 12:37 AM
RE: 38-1 code 121A - by Radioroslyn - 09-28-2017, 02:29 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 03:01 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 02:39 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 02:51 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:13 PM
RE: 38-1 code 121A - by morzh - 10-28-2017, 04:04 PM
RE: 38-1 code 121A - by Radioroslyn - 10-28-2017, 04:12 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 05:16 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 12:33 AM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 11:50 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:05 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:10 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:18 PM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 10:25 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-11-2017, 04:33 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 02:21 AM
RE: 38-1 code 121A - by Ron Ramirez - 11-18-2017, 08:05 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 10:17 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-24-2017, 11:45 PM
RE: 38-1 code 121A - by Radioroslyn - 11-25-2017, 10:42 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 03:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 02:02 AM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 12:27 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 12:31 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 12:44 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:03 PM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 01:47 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 07:33 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-29-2017, 10:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-03-2017, 06:55 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 04:53 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 06:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 07:35 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 07:52 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 09:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 12:20 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 05:48 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-25-2017, 03:42 PM
RE: 38-1 code 121A - by EdHolland - 12-26-2017, 09:45 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-27-2017, 06:16 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3913 online users. [Complete List]
» 1 Member(s) | 3912 Guest(s)
