philco 9-0 schematic
okay i am working on a philco 90 and I am looking for the schematic for it. I have the one with the one 47 tube but I have an extra bake lite cap in it the number on it is 4989-j I find the cap on the 490 schematic so can some one direct me to the right drawing
benny
philco 9-0 schematic - by mg34.42 - 11-18-2017, 10:15 PM
RE: philco 9-0 schematic - by vinzer - 11-18-2017, 10:27 PM
RE: philco 9-0 schematic - by morzh - 11-18-2017, 11:59 PM
RE: philco 9-0 schematic - by Nathan Slingerland - 11-19-2017, 12:57 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4367 online users. [Complete List]
» 1 Member(s) | 4366 Guest(s)
