38-1 code 121A
>. YES?
Yes.
> correctly, as the positive leg appears to be going to ground...
Yes.
>Is this chassis ground
Yes.
> the positive of the 10uf (#102) was grounded there?
Don't know, doesn't matter as long as it's at chassis ground.
38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 12:37 AM
RE: 38-1 code 121A - by Radioroslyn - 09-28-2017, 02:29 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 09-28-2017, 03:01 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 02:39 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 02:51 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 03:13 PM
RE: 38-1 code 121A - by morzh - 10-28-2017, 04:04 PM
RE: 38-1 code 121A - by Radioroslyn - 10-28-2017, 04:12 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 10-28-2017, 05:16 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 12:33 AM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 11:50 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:05 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:10 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:18 PM
RE: 38-1 code 121A - by Radioroslyn - 11-08-2017, 10:25 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-08-2017, 10:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-11-2017, 04:33 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 02:21 AM
RE: 38-1 code 121A - by Ron Ramirez - 11-18-2017, 08:05 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-18-2017, 10:17 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-24-2017, 11:45 PM
RE: 38-1 code 121A - by Radioroslyn - 11-25-2017, 10:42 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-25-2017, 03:35 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 02:02 AM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 12:27 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 12:31 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 12:44 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 01:03 PM
RE: 38-1 code 121A - by Radioroslyn - 11-28-2017, 01:47 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-28-2017, 07:33 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 11-29-2017, 10:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-03-2017, 06:55 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 04:53 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 06:38 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 07:35 PM
RE: 38-1 code 121A - by Radioroslyn - 12-04-2017, 07:52 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-04-2017, 09:13 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 12:20 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-16-2017, 05:48 AM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-25-2017, 03:42 PM
RE: 38-1 code 121A - by EdHolland - 12-26-2017, 09:45 PM
RE: 38-1 code 121A - by Electrothaumaturgist - 12-27-2017, 06:16 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
