A Model 16X story
The original Philco U-2 speaker is 10-1/2 inches in diameter. The eBay cone would be too large, plus the voice coil appears to be 1 inch - too small. And then there's the problem of it having an external spider rather than internal (within the voice coil).
The eBay cone is likely for a 1939-42 (and possibly newer) 12 inch speaker.
A Model 16X story - by EdHolland - 11-26-2017, 08:32 PM
RE: A Model 16X story - by morzh - 11-26-2017, 08:50 PM
RE: A Model 16X story - by VntgRads - 11-27-2017, 01:39 AM
RE: A Model 16X story - by EdHolland - 11-27-2017, 02:16 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 02:37 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 05:18 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 08:15 PM
RE: A Model 16X story - by sam - 11-28-2017, 11:59 AM
RE: A Model 16X story - by EdHolland - 11-28-2017, 12:46 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:04 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:38 PM
RE: A Model 16X story - by morzh - 11-28-2017, 02:08 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:21 PM
RE: A Model 16X story - by morzh - 11-28-2017, 04:49 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 07:18 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 12:23 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 12:29 PM
RE: A Model 16X story - by klondike98 - 11-29-2017, 12:53 PM
RE: A Model 16X story - by morzh - 11-29-2017, 01:13 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:43 PM
RE: A Model 16X story - by morzh - 11-29-2017, 02:40 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 03:22 PM
RE: A Model 16X story - by morzh - 11-29-2017, 04:14 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 05:46 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 06:26 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 09:28 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 10:08 PM
RE: A Model 16X story - by Steve Davis - 11-29-2017, 10:17 PM
RE: A Model 16X story - by Electrothaumaturgist - 11-29-2017, 10:26 PM
RE: A Model 16X story - by EdHolland - 12-04-2017, 02:46 PM
RE: A Model 16X story - by EdHolland - 12-08-2017, 02:55 PM
RE: A Model 16X story - by EdHolland - 12-11-2017, 12:39 PM
RE: A Model 16X story - by EdHolland - 12-23-2017, 08:47 PM
RE: A Model 16X story - by EdHolland - 12-26-2017, 09:55 PM
RE: A Model 16X story - by Brad Winder - 12-26-2017, 11:18 PM
RE: A Model 16X story - by Ron Ramirez - 12-27-2017, 11:23 AM
RE: A Model 16X story - by EdHolland - 12-27-2017, 10:46 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 11:47 AM
RE: A Model 16X story - by EdHolland - 12-31-2017, 04:50 PM
RE: A Model 16X story - by EdHolland - 01-06-2018, 09:29 PM
RE: A Model 16X story - by EdHolland - 01-07-2018, 10:43 PM
RE: A Model 16X story - by EdHolland - 01-11-2018, 12:36 PM
RE: A Model 16X story - by EdHolland - 01-12-2018, 05:13 PM
RE: A Model 16X story - by EdHolland - 01-14-2018, 07:21 PM
RE: A Model 16X story - by morzh - 01-14-2018, 07:53 PM
RE: A Model 16X story - by EdHolland - 01-15-2018, 01:22 PM
RE: A Model 16X story - by morzh - 01-15-2018, 01:26 PM
RE: A Model 16X story - by EdHolland - 01-17-2018, 11:59 AM
RE: A Model 16X story - by EdHolland - 01-19-2018, 06:58 PM
RE: A Model 16X story - by EdHolland - 01-20-2018, 09:46 PM
RE: A Model 16X story - by 462ron - 01-21-2018, 12:47 PM
RE: A Model 16X story - by EdHolland - 01-21-2018, 09:39 PM
RE: A Model 16X story - by 462ron - 01-22-2018, 12:14 AM
RE: A Model 16X story - by EdHolland - 04-02-2018, 01:06 PM
RE: A Model 16X story - by gregb - 04-02-2018, 02:47 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
