Sorta newbie 38-690 low volume
Hi Mike,
I only have one wire that goes to the cable and a cap.  I'm wondering if that is a ground for the multi-lytic #110, which I would have removed.  As you can see, I'm not a re-stuffer.  But I've been called worse. Icon_lol
BTY, you had asked if my volume goes up when I touch the antenna and YES, it most certainly does, quite a bit.  I didn't try the tube caps.  Is that the top connector on the the RF tubes?  I wasn't sure.  So does that indicate a possible open tuning coil (one of the 14 in the 690).  Please excuse if I get the terminology incorrect.  I'm still a beginner.
Sorta newbie 38-690 low volume - by Hot Rod - 11-29-2017, 08:35 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-29-2017, 11:22 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 12:46 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 01:08 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 11-30-2017, 06:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 11-30-2017, 11:15 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 11:13 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-01-2017, 12:08 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-01-2017, 03:36 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 04:50 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 06:20 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-03-2017, 06:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-03-2017, 10:24 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-05-2017, 08:33 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 06:44 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 06:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-05-2017, 08:28 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-05-2017, 11:03 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-06-2017, 12:45 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-06-2017, 01:26 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 07:37 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 07:46 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-07-2017, 08:47 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-07-2017, 10:57 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-08-2017, 12:19 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-08-2017, 01:39 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-08-2017, 11:21 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 10:26 AM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 01:39 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 03:01 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-09-2017, 07:04 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-09-2017, 08:37 PM
RE: Sorta newbie 38-690 low volume - by Hot Rod - 12-10-2017, 07:01 PM
RE: Sorta newbie 38-690 low volume - by morzh - 12-10-2017, 07:23 PM
