A Model 16X story
#46
Thanks morz,
That is exactly what I thought. Anything that was obviously a flagship product, and has survived (mostly) intact deserves attention. The sheer number and size of components on the chassis tell you this was a serious product in its day.
Next steps are to do an R.F. alignment, although broadcast band was working very well already. The shadow meter worked wonderfully - worth rewinding the coil! It was hard to judge sound quality with the speaker face down on the bench, resting on a couple of wooden blocks (So I could test the wiring one last time), but I could hear good highs and lows, and response to the tone control switch. And my goodness, this thing will go loud!
Ed
A Model 16X story - by EdHolland - 11-26-2017, 08:32 PM
RE: A Model 16X story - by morzh - 11-26-2017, 08:50 PM
RE: A Model 16X story - by VntgRads - 11-27-2017, 01:39 AM
RE: A Model 16X story - by EdHolland - 11-27-2017, 02:16 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 02:37 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 05:18 PM
RE: A Model 16X story - by EdHolland - 11-27-2017, 08:15 PM
RE: A Model 16X story - by sam - 11-28-2017, 11:59 AM
RE: A Model 16X story - by EdHolland - 11-28-2017, 12:46 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:04 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 01:38 PM
RE: A Model 16X story - by morzh - 11-28-2017, 02:08 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 02:21 PM
RE: A Model 16X story - by morzh - 11-28-2017, 04:49 PM
RE: A Model 16X story - by EdHolland - 11-28-2017, 07:18 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 12:23 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 12:29 PM
RE: A Model 16X story - by klondike98 - 11-29-2017, 12:53 PM
RE: A Model 16X story - by morzh - 11-29-2017, 01:13 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 01:43 PM
RE: A Model 16X story - by morzh - 11-29-2017, 02:40 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 03:22 PM
RE: A Model 16X story - by morzh - 11-29-2017, 04:14 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 05:46 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 06:26 PM
RE: A Model 16X story - by Ron Ramirez - 11-29-2017, 09:28 PM
RE: A Model 16X story - by EdHolland - 11-29-2017, 10:08 PM
RE: A Model 16X story - by Steve Davis - 11-29-2017, 10:17 PM
RE: A Model 16X story - by Electrothaumaturgist - 11-29-2017, 10:26 PM
RE: A Model 16X story - by EdHolland - 12-04-2017, 02:46 PM
RE: A Model 16X story - by EdHolland - 12-08-2017, 02:55 PM
RE: A Model 16X story - by EdHolland - 12-11-2017, 12:39 PM
RE: A Model 16X story - by EdHolland - 12-23-2017, 08:47 PM
RE: A Model 16X story - by EdHolland - 12-26-2017, 09:55 PM
RE: A Model 16X story - by Brad Winder - 12-26-2017, 11:18 PM
RE: A Model 16X story - by Ron Ramirez - 12-27-2017, 11:23 AM
RE: A Model 16X story - by EdHolland - 12-27-2017, 10:46 PM
RE: A Model 16X story - by EdHolland - 12-31-2017, 11:47 AM
RE: A Model 16X story - by EdHolland - 12-31-2017, 04:50 PM
RE: A Model 16X story - by EdHolland - 01-06-2018, 09:29 PM
RE: A Model 16X story - by EdHolland - 01-07-2018, 10:43 PM
RE: A Model 16X story - by EdHolland - 01-11-2018, 12:36 PM
RE: A Model 16X story - by EdHolland - 01-12-2018, 05:13 PM
RE: A Model 16X story - by EdHolland - 01-14-2018, 07:21 PM
RE: A Model 16X story - by morzh - 01-14-2018, 07:53 PM
RE: A Model 16X story - by EdHolland - 01-15-2018, 01:22 PM
RE: A Model 16X story - by morzh - 01-15-2018, 01:26 PM
RE: A Model 16X story - by EdHolland - 01-17-2018, 11:59 AM
RE: A Model 16X story - by EdHolland - 01-19-2018, 06:58 PM
RE: A Model 16X story - by EdHolland - 01-20-2018, 09:46 PM
RE: A Model 16X story - by 462ron - 01-21-2018, 12:47 PM
RE: A Model 16X story - by EdHolland - 01-21-2018, 09:39 PM
RE: A Model 16X story - by 462ron - 01-22-2018, 12:14 AM
RE: A Model 16X story - by EdHolland - 04-02-2018, 01:06 PM
RE: A Model 16X story - by gregb - 04-02-2018, 02:47 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
