Model 70
#35
OK,, I forgot about Speaker.. I think I have a bad Transformer.. I will double check.. But how do you get the transformer off??
I would assume drilling the rivets  But Not really sure how to do that with out damaging the speaker..
Help...
[Image: https://farm5.staticflickr.com/4743/2593...5a7b_b.jpg]
Skip...
Model 70 - by vecher - 11-29-2017, 08:41 PM
RE: Model 70 - by Ron Ramirez - 11-29-2017, 09:33 PM
RE: Model 70 - by vecher - 12-02-2017, 12:55 AM
RE: Model 70 - by Arran - 12-02-2017, 02:46 AM
RE: Model 70 - by Steve Davis - 12-02-2017, 07:53 AM
RE: Model 70 - by vecher - 12-02-2017, 01:30 PM
RE: Model 70 - by vecher - 12-02-2017, 03:40 PM
RE: Model 70 - by vecher - 12-03-2017, 10:23 AM
RE: Model 70 - by morzh - 12-03-2017, 11:20 AM
RE: Model 70 - by vecher - 12-24-2017, 11:40 PM
RE: Model 70 - by AudreyHepburn - 12-29-2017, 10:14 PM
RE: Model 70 - by vecher - 12-29-2017, 10:59 PM
RE: Model 70 - by Radioroslyn - 12-29-2017, 11:36 PM
RE: Model 70 - by TV MAN - 12-30-2017, 10:30 PM
RE: Model 70 - by vecher - 12-31-2017, 01:19 AM
RE: Model 70 - by vecher - 01-06-2018, 11:17 PM
RE: Model 70 - by klondike98 - 01-07-2018, 08:16 AM
RE: Model 70 - by Steve Davis - 01-07-2018, 09:46 AM
RE: Model 70 - by Ron Ramirez - 01-07-2018, 09:52 AM
RE: Model 70 - by vecher - 01-07-2018, 11:53 AM
RE: Model 70 - by vecher - 01-10-2018, 11:15 AM
RE: Model 70 - by Steve Davis - 01-10-2018, 11:36 AM
RE: Model 70 - by klondike98 - 01-10-2018, 12:07 PM
RE: Model 70 - by vecher - 01-10-2018, 01:08 PM
RE: Model 70 - by morzh - 01-10-2018, 04:05 PM
RE: Model 70 - by klondike98 - 01-10-2018, 05:25 PM
RE: Model 70 - by Warren - 01-10-2018, 08:17 PM
RE: Model 70 - by vecher - 01-10-2018, 11:59 PM
RE: Model 70 - by vecher - 01-11-2018, 12:12 AM
RE: Model 70 - by Steve Davis - 01-11-2018, 01:00 AM
RE: Model 70 - by morzh - 01-11-2018, 08:36 AM
RE: Model 70 - by vecher - 01-13-2018, 07:18 PM
RE: Model 70 - by vecher - 01-13-2018, 07:21 PM
RE: Model 70 - by vecher - 01-16-2018, 11:13 PM
RE: Model 70 - by vecher - 01-20-2018, 08:17 PM
RE: Model 70 - by Steve Davis - 01-20-2018, 11:07 PM
RE: Model 70 - by EdHolland - 01-21-2018, 02:33 AM
RE: Model 70 - by Steve D - 01-21-2018, 10:49 AM
RE: Model 70 - by vecher - 01-21-2018, 01:22 PM
RE: Model 70 - by vecher - 01-21-2018, 05:02 PM
RE: Model 70 - by vecher - 01-21-2018, 11:02 PM
RE: Model 70 - by vecher - 01-22-2018, 08:47 PM
RE: Model 70 - by vecher - 01-28-2018, 10:25 PM
RE: Model 70 - by mg34.42 - 03-18-2018, 02:32 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3916 online users. [Complete List]
» 1 Member(s) | 3915 Guest(s)
