Stuck Antenna and Ground Posts?
Ok, I must be doing something wrong.  I just finished my Philco 77 and it is playing great.  The antenna and ground posts are obviously spring-loaded but they won't push down to accept the antenna and ground wires.  I have WD40ed them both but still no luck.  Anyone see this problem before and if so how did you fix it?  Or is it operator error on my part?
Joe
Stuck Antenna and Ground Posts? - by jamr005 - 03-05-2018, 01:28 PM
RE: Stuck Antenna and Ground Posts? - by morzh - 03-05-2018, 02:03 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2006 online users. [Complete List]
» 3 Member(s) | 2003 Guest(s)
