Restoring a Predicta Tandem
Nothing special that I know of, but make sure there is a center ground post if the original has one.
I got mine from Surplus Sales of Nebraska.
7P-CP for the 7-pin. Remove the shield if you don't need it. Might be a cheaper source out there. I'm not sure.
751V504C06 for the 9-pin. It's a perfect match with thicker metal used. 28,000 in stock Icon_smile
Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 01:39 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 04:01 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 05:40 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 10:08 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-28-2018, 02:46 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 11:27 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 12:03 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 12:13 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 12:18 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 01:55 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 10:56 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-06-2018, 05:07 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 07:01 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 07:54 AM
RE: Restoring a Predicta Tandem - by gregb - 03-07-2018, 09:06 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 10:39 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 11:24 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-07-2018, 12:06 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 12:29 PM
RE: Restoring a Predicta Tandem - by TV MAN - 03-11-2018, 05:39 PM
RE: Restoring a Predicta Tandem - by Arran - 03-13-2018, 03:00 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-13-2018, 08:03 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-17-2018, 08:19 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 10:47 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-19-2018, 11:03 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-19-2018, 11:57 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 02:25 PM
RE: Restoring a Predicta Tandem - by Arran - 03-22-2018, 03:55 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-22-2018, 07:31 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-23-2018, 07:17 AM
RE: Restoring a Predicta Tandem - by Arran - 03-24-2018, 12:27 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-29-2018, 10:12 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-29-2018, 11:19 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 09:57 AM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 11:13 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 02:52 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 03:06 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 05:36 PM
RE: Restoring a Predicta Tandem - by Arran - 04-07-2018, 03:26 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-26-2018, 04:40 AM
RE: Restoring a Predicta Tandem - by gregb - 04-26-2018, 08:01 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5198 online users. [Complete List]
» 1 Member(s) | 5197 Guest(s)
