My Philco 53-960
I bought this radio almost two years ago and finally got around to refurbishing it.  Just finished and I'm happy with how it sounds.  I read threads on the Phorum about restoration of the 53-960 and found very useful information.  Thanks to those authors for helping me.  Next job is a high school classmate's Philco 38-3.
You can see and hear it at https://youtu.be/yVo3Q8siVig
Larry
My Philco 53-960 - by LarryFS - 03-11-2018, 06:38 PM
RE: My Philco 53-960 - by morzh - 03-11-2018, 06:40 PM
RE: My Philco 53-960 - by KCMike - 03-11-2018, 07:08 PM
RE: My Philco 53-960 - by Bill Bacco - 03-11-2018, 08:29 PM
RE: My Philco 53-960 - by LarryFS - 03-11-2018, 09:21 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
