Restoring a Predicta Tandem
I believe it's called mold [Image: http://philcoradio.com/phorum/images/smi...n_razz.gif].
It will an annual event as it comes back along w/ the vomit smell.
I love Predictas.
Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 01:39 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 04:01 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 05:40 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 10:08 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-28-2018, 02:46 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 11:27 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 12:03 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 12:13 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 12:18 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 01:55 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 10:56 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-06-2018, 05:07 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 07:01 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 07:54 AM
RE: Restoring a Predicta Tandem - by gregb - 03-07-2018, 09:06 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 10:39 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 11:24 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-07-2018, 12:06 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 12:29 PM
RE: Restoring a Predicta Tandem - by TV MAN - 03-11-2018, 05:39 PM
RE: Restoring a Predicta Tandem - by Arran - 03-13-2018, 03:00 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-13-2018, 08:03 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-17-2018, 08:19 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 10:47 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-19-2018, 11:03 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-19-2018, 11:57 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 02:25 PM
RE: Restoring a Predicta Tandem - by Arran - 03-22-2018, 03:55 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-22-2018, 07:31 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-23-2018, 07:17 AM
RE: Restoring a Predicta Tandem - by Arran - 03-24-2018, 12:27 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-29-2018, 10:12 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-29-2018, 11:19 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 09:57 AM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 11:13 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 02:52 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 03:06 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 05:36 PM
RE: Restoring a Predicta Tandem - by Arran - 04-07-2018, 03:26 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-26-2018, 04:40 AM
RE: Restoring a Predicta Tandem - by gregb - 04-26-2018, 08:01 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3353 online users. [Complete List]
» 2 Member(s) | 3351 Guest(s)
