03-21-2018, 02:58 PM
The first cap of the rectifier is usually chosen to set a certain B+ voltage. The higher the capacitance, the higher the voltage will be. But this is only due to the high output resistance of rectifier tubes. Semiconductor diodes have very low resistance, so your voltage might go up quite a bit. Hence what Olskuul said about the resistor. Which could be chosen close to that tube's resistance.
