RCA 10T
I checked out a bunch of posts involving the 10T. There are a few threads on ARF, and even a full blown resto thread with detailed pics, et al. It certainly does have the gutta/percha stuff all up in there and all over. And the fact that every RCA I've ever worked on has made me very happy and satisfied- is so appealing to me at this time. I am in need of another project. If I were to get it, I would trust few to repair the cabinet properly, but it has your name all over it, Russ. I really do like this radio a lot, but I would never be happy with it without the cabinet getting professionally restored. But paying someone to do it for me will never happen. Maybe we can figure out a way to get it to you.
RCA 10T - by Electrothaumaturgist - 04-27-2018, 12:02 AM
RE: RCA 10T - by Arran - 04-27-2018, 03:15 AM
RE: RCA 10T - by Electrothaumaturgist - 04-27-2018, 04:49 PM
RE: RCA 10T - by Phlogiston - 04-27-2018, 05:12 PM
RE: RCA 10T - by Paul Philco322 - 04-27-2018, 07:32 PM
RE: RCA 10T - by Electrothaumaturgist - 04-27-2018, 07:37 PM
RE: RCA 10T - by Phlogiston - 04-27-2018, 08:38 PM
RE: RCA 10T - by Electrothaumaturgist - 04-27-2018, 10:07 PM
RE: RCA 10T - by Arran - 04-28-2018, 02:40 AM
RE: RCA 10T - by Phlogiston - 04-28-2018, 09:28 AM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:28 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:33 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:35 PM
RE: RCA 10T - by Phlogiston - 04-28-2018, 06:36 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:42 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:45 PM
RE: RCA 10T - by Phlogiston - 04-28-2018, 06:48 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:49 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:51 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 06:53 PM
RE: RCA 10T - by Phlogiston - 04-28-2018, 07:05 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 07:09 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 07:17 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 07:19 PM
RE: RCA 10T - by Phlogiston - 04-28-2018, 08:21 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 08:30 PM
RE: RCA 10T - by Electrothaumaturgist - 04-28-2018, 08:45 PM
RE: RCA 10T - by Arran - 04-29-2018, 01:00 AM
RE: RCA 10T - by Electrothaumaturgist - 04-29-2018, 12:10 PM
RE: RCA 10T - by Ron Ramirez - 04-29-2018, 12:24 PM
RE: RCA 10T - by Phlogiston - 04-29-2018, 09:09 PM
RE: RCA 10T - by NostalgiaRadioTime - 04-29-2018, 09:22 PM
RE: RCA 10T - by Electrothaumaturgist - 04-29-2018, 11:31 PM
RE: RCA 10T - by Electrothaumaturgist - 04-29-2018, 11:43 PM
RE: RCA 10T - by Phlogiston - 04-30-2018, 09:36 AM
RE: RCA 10T - by Phlogiston - 04-30-2018, 11:36 AM
RE: RCA 10T - by Electrothaumaturgist - 05-04-2018, 11:41 PM
RE: RCA 10T - by Ron Ramirez - 05-05-2018, 09:13 AM
RE: RCA 10T - by PhilcoJohn - 05-15-2018, 06:05 PM
RE: RCA 10T - by Electrothaumaturgist - 05-15-2018, 08:07 PM
RE: RCA 10T - by Brad Winder - 05-15-2018, 09:54 PM
RE: RCA 10T - by Phlogiston - 05-15-2018, 10:02 PM
RE: RCA 10T - by Ron Ramirez - 05-16-2018, 05:18 AM
RE: RCA 10T - by Brad Winder - 05-21-2018, 05:28 PM
RE: RCA 10T - by Ron Ramirez - 05-21-2018, 06:35 PM
RE: RCA 10T - by Phlogiston - 05-21-2018, 10:16 PM
RE: RCA 10T - by Arran - 05-22-2018, 01:41 AM
RE: RCA 10T - by radiohenry - 05-22-2018, 11:26 AM
RE: RCA 10T - by radiohenry - 05-23-2018, 01:59 PM
RE: RCA 10T - by Electrothaumaturgist - 05-23-2018, 04:41 PM
RE: RCA 10T - by Ron Ramirez - 05-23-2018, 04:57 PM
RE: RCA 10T - by radiohenry - 05-24-2018, 06:39 AM
RE: RCA 10T - by Electrothaumaturgist - 05-24-2018, 05:05 PM
RE: RCA 10T - by NostalgiaRadioTime - 05-24-2018, 05:49 PM
RE: RCA 10T - by Electrothaumaturgist - 05-24-2018, 06:04 PM
RE: RCA 10T - by NostalgiaRadioTime - 05-24-2018, 10:48 PM
RE: RCA 10T - by Arran - 05-25-2018, 02:20 AM
RE: RCA 10T - by radiohenry - 05-27-2018, 11:30 AM
RE: RCA 10T - by Electrothaumaturgist - 05-27-2018, 10:40 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 02:50 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 03:14 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 03:27 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 03:42 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 03:51 PM
RE: RCA 10T - by Eliot Ness - 09-08-2020, 03:58 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 04:01 PM
RE: RCA 10T - by Electrothaumaturgist - 09-08-2020, 04:27 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3900 online users. [Complete List]
» 2 Member(s) | 3898 Guest(s)
