Need help ID'ing console ('29 Model 65?)
That's possibly a Model 65, 76 or 87 cabinet. The chassis is a Model 65 from 1929. The cabinet may not be be the original. Either the wooden grille work was removed from the stock 65 cabinet, or the cabinet is from a Model 76 or Model 87. Models 40, 65, 76, and the early 95 used that cabinet - the 76 and 87 came standard without the extra grille work.
Here is the Model 65:
[Image: http://radioatticarchives.com/images/p/P...m_Boyd.jpg]
[No subject] - by Chuck Schwark - 01-30-2006, 11:21 PM
[No subject] - by noiseguy - 01-31-2006, 08:55 AM
[No subject] - by Ron Ramirez - 01-31-2006, 08:59 AM
[No subject] - by Chuck Schwark - 01-31-2006, 09:03 AM
[No subject] - by Ron Ramirez - 01-31-2006, 12:06 PM
[No subject] - by rjm - 01-31-2006, 02:33 PM
[No subject] - by noiseguy - 02-01-2006, 10:40 PM
[No subject] - by Chuck Schwark - 02-01-2006, 10:52 PM
[No subject] - by noiseguy - 02-02-2006, 04:09 PM
[No subject] - by Chuck Schwark - 02-02-2006, 04:44 PM
[No subject] - by noiseguy - 02-17-2006, 12:09 PM
[No subject] - by rjm - 02-17-2006, 01:15 PM
[No subject] - by noiseguy - 03-26-2006, 11:45 PM
[No subject] - by rjm - 03-27-2006, 01:01 AM
[No subject] - by noiseguy - 03-27-2006, 08:12 AM
[No subject] - by noiseguy - 03-27-2006, 08:34 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
