Philco model 89 code 121 need help
I am trying to understand what’s going on with a model 89 code 121 power supply.
It’s the first model.  #36 tube for the oscillator. The filter capacitors are numbered C44 & C46.
 I only have the rectifier tube (80) in the circuit.  The tube, transformer and speaker all check out ok.
The voltages across the transformer are all in spec. when the leads are removed from the circuit.
I substituted 2 (10mf) 450V electrolytic Capacitors for the filter caps, after disconnecting the original caps.
Powering up with just enough time to take measurements then shutting down, I do not see any rectification across the capacitor C44.
( full wave 60 cycle ac)  I read 110VAC  50VDC.
C46 also does not show any rectification And reads 2VAC  53VDC   any help or ideas would be appreciated.
Tom R
Philco model 89 code 121 need help - by tmr63 - 06-21-2018, 03:47 PM
RE: Philco model 89 code 121 need help - by tmr63 - 07-13-2018, 08:00 AM
RE: Philco model 89 code 121 need help - by morzh - 07-13-2018, 09:22 AM
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 2985 online users. [Complete List]
» 3 Member(s) | 2982 Guest(s)
