Predicta Siesta scored
wow..gets plug into a socket,,,neat
Predicta Siesta scored - by Bob Andersen - 06-27-2018, 05:46 PM
RE: Predicta Siesta scored - by Ed Locker - 06-27-2018, 06:40 PM
RE: Predicta Siesta scored - by Radioroslyn - 06-27-2018, 06:41 PM
RE: Predicta Siesta scored - by Ed Locker - 06-27-2018, 06:43 PM
RE: Predicta Siesta scored - by Bob Andersen - 06-28-2018, 02:14 PM
RE: Predicta Siesta scored - by Bob Andersen - 06-28-2018, 04:51 PM
RE: Predicta Siesta scored - by Bob Andersen - 06-28-2018, 04:54 PM
RE: Predicta Siesta scored - by Steve Davis - 06-28-2018, 08:04 PM
RE: Predicta Siesta scored - by Bob Andersen - 06-29-2018, 11:23 AM
RE: Predicta Siesta scored - by Radioroslyn - 06-29-2018, 01:42 PM
RE: Predicta Siesta scored - by Arran - 07-04-2018, 04:24 AM
RE: Predicta Siesta scored - by Bob Andersen - 07-06-2018, 10:09 AM
RE: Predicta Siesta scored - by morzh - 07-06-2018, 10:55 AM
RE: Predicta Siesta scored - by Bob Andersen - 07-07-2018, 03:08 AM
RE: Predicta Siesta scored - by Radioroslyn - 07-07-2018, 03:38 PM
RE: Predicta Siesta scored - by Kenneth F. Besso Jr. - 07-07-2018, 06:34 PM
RE: Predicta Siesta scored - by Arran - 07-15-2018, 04:28 AM
RE: Predicta Siesta scored - by TV MAN - 07-18-2018, 09:43 PM
RE: Predicta Siesta scored - by MrFixr55 - 11-27-2020, 11:02 PM
RE: Predicta Siesta scored - by Radioroslyn - 11-28-2020, 12:42 PM
RE: Predicta Siesta scored - by Bob Andersen - 12-03-2021, 03:43 PM
RE: Predicta Siesta scored - by Bob Andersen - 12-03-2021, 03:47 PM
RE: Predicta Siesta scored - by Bob Andersen - 12-03-2021, 03:50 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4435 online users. [Complete List]
» 1 Member(s) | 4434 Guest(s)
