RCA 110K2 Unexpected project
#81
More today, mostly fiddling with alignment, but one other important step forward.
Following the datasheet calls for set-up of the 2nd, then the first IF. When I try injecting a signal as specified, this kills the stage completely. Instead, I found a "gimmick" insulated wire wrapped loosely around the same point, I was able to inject and hear 455 kHz from my generator. This wasn't working quite as expected, as the adjustment of the second IF still showed rather little response - but there was enough pickup from the first stage that it did respond, and I could tune the first IF.
Jiggling things around a bit, I find it is possible to get first and second IFs to peak up, although I do feel this could be improved upon. There are also periodic crackles from the radio after switch on from cold, so I may investigate for "silver Mica disease".
Aligning the front end is very rudimentary on this radio, and seems to fall in just fine, although there is one anomaly. The 31 m "Spread Band" is derived from the 6-18 megahertz band using padding and trimming capacitors. However, the oscillator trimmer has to be adjusted to maximum to meet the set point. It is in parallel with a tubular ceramic (82 pf) and I wonder if this has drifted in value over the years.
All this fiddling around had, until today, ignored one thing - terrible audio from the speaker. For one thing, the surround had detached from the frame, making for a big "slap" on heavy bass accents. But also, the voice coil was rubbing. Looking closer, there were two screws adjacent to the field coil. These secured clamps that held a plate to which the spider is attached. A little adjustment restored clean movement to the voice coil, and lovely audio.
Cheers
Ed
RCA 110K2 Unexpected project - by EdHolland - 03-10-2018, 06:05 PM
RE: RCA 110K2 Unexpected project - by Arran - 03-11-2018, 12:04 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-11-2018, 11:35 AM
RE: RCA 110K2 Unexpected project - by David - 03-11-2018, 06:47 PM
RE: RCA 110K2 Unexpected project - by Arran - 03-11-2018, 07:10 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-11-2018, 07:42 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-16-2018, 12:54 PM
RE: RCA 110K2 Unexpected project - by David - 03-16-2018, 03:23 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-16-2018, 08:14 PM
RE: RCA 110K2 Unexpected project - by Arran - 03-16-2018, 08:21 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-17-2018, 12:56 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-17-2018, 10:33 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-18-2018, 04:12 PM
RE: RCA 110K2 Unexpected project - by Arran - 03-18-2018, 10:46 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-19-2018, 04:49 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 03-22-2018, 01:06 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-01-2018, 10:26 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-02-2018, 01:13 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-04-2018, 04:29 PM
RE: RCA 110K2 Unexpected project - by Arran - 04-05-2018, 03:42 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-05-2018, 11:30 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-07-2018, 10:18 PM
RE: RCA 110K2 Unexpected project - by Arran - 04-07-2018, 11:30 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-08-2018, 02:57 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-09-2018, 03:13 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-10-2018, 07:29 PM
RE: RCA 110K2 Unexpected project - by Arran - 04-10-2018, 11:17 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-11-2018, 03:14 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-14-2018, 04:04 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-15-2018, 09:26 PM
RE: RCA 110K2 Unexpected project - by Arran - 04-16-2018, 03:56 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-16-2018, 03:12 PM
RE: RCA 110K2 Unexpected project - by Arran - 04-17-2018, 01:24 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-17-2018, 01:51 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-21-2018, 12:17 AM
RE: RCA 110K2 Unexpected project - by Steve Davis - 04-21-2018, 06:07 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-21-2018, 08:44 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-28-2018, 09:06 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 04-29-2018, 10:44 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-06-2018, 10:36 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-12-2018, 10:13 PM
RE: RCA 110K2 Unexpected project - by Arran - 05-13-2018, 11:33 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-14-2018, 01:04 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-20-2018, 09:49 PM
RE: RCA 110K2 Unexpected project - by Arran - 05-21-2018, 03:07 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-21-2018, 11:48 AM
RE: RCA 110K2 Unexpected project - by Arran - 05-22-2018, 01:10 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-22-2018, 12:42 PM
RE: RCA 110K2 Unexpected project - by Arran - 05-23-2018, 12:45 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-23-2018, 10:16 AM
RE: RCA 110K2 Unexpected project - by Arran - 05-23-2018, 11:12 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-24-2018, 11:36 AM
RE: RCA 110K2 Unexpected project - by Ron Ramirez - 05-24-2018, 09:11 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 05-25-2018, 12:07 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-02-2018, 10:28 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-04-2018, 02:59 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-09-2018, 11:02 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-11-2018, 01:49 PM
RE: RCA 110K2 Unexpected project - by Arran - 06-12-2018, 02:27 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-12-2018, 12:02 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-17-2018, 11:09 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-18-2018, 08:00 PM
RE: RCA 110K2 Unexpected project - by Arran - 06-20-2018, 02:01 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-20-2018, 11:48 AM
RE: RCA 110K2 Unexpected project - by David - 06-20-2018, 02:06 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-21-2018, 01:56 PM
RE: RCA 110K2 Unexpected project - by David - 06-21-2018, 04:06 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-23-2018, 09:47 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-25-2018, 01:46 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-26-2018, 12:36 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 06-30-2018, 10:28 PM
RE: RCA 110K2 Unexpected project - by Arran - 07-01-2018, 03:18 PM
RE: RCA 110K2 Unexpected project - by David - 07-01-2018, 07:46 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-01-2018, 09:49 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-02-2018, 10:29 PM
RE: RCA 110K2 Unexpected project - by Arran - 07-04-2018, 02:43 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-04-2018, 09:26 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-07-2018, 10:20 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-11-2018, 12:55 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-16-2018, 02:03 PM
RE: RCA 110K2 Unexpected project - by Arran - 07-17-2018, 04:18 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-17-2018, 07:48 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-22-2018, 05:55 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-29-2018, 09:48 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 07-30-2018, 03:03 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-06-2018, 08:56 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-07-2018, 09:27 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-12-2018, 12:19 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-13-2018, 02:47 PM
RE: RCA 110K2 Unexpected project - by PhilcoJohn - 10-15-2018, 07:18 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-21-2018, 11:58 AM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-21-2018, 09:36 PM
RE: RCA 110K2 Unexpected project - by Eliot Ness - 10-21-2018, 09:52 PM
RE: RCA 110K2 Unexpected project - by EdHolland - 10-22-2018, 02:14 PM
