Ron's RCA 6T2 Restoration
#40
Thanks Greg...
...unfortunately, spraying the next two coats of clear revealed that the drip spots were still showing. Icon_sad
In addition, it was really hot and very humid when I sprayed the second two coats, so the finish did not turn out well - it had a powdery appearance in some areas of the cabinet. Yes, I know - it was the result of spraying lacquer when the weather is too hot and humid. The lacquer was drying in areas before it hit the cabinet.
I wet sanded the cabinet again today, going down to 600 grit and getting a bit more aggressive with the drip spots. Fortunately I did not burn through the toner (knocking wood), and the spots look better/smoother than ever now. Whether they will (mostly) disappear after the next two coats remains to be seen. The entire cabinet has been smoothed out by the wet sanding, although I need to wet sand the sides some more. The top and front are ready for the next coats.
The weather is supposed to be a bit milder tomorrow with less humidity, so I guess I'll try it again. I'm hoping the cabinet turns out smoother this time.
Ron's RCA 6T2 Restoration - by Ron Ramirez - 07-24-2018, 07:40 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 07-24-2018, 07:44 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 07-24-2018, 09:21 PM
RE: Ron's RCA 6T2 Restoration - by Arran - 07-28-2018, 02:25 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 08-26-2018, 03:36 PM
RE: Ron's RCA 6T2 Restoration - by Eliot Ness - 08-26-2018, 08:40 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 08-26-2018, 08:43 PM
RE: Ron's RCA 6T2 Restoration - by Arran - 08-27-2018, 02:29 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 08-27-2018, 05:09 AM
RE: Ron's RCA 6T2 Restoration - by Dan Walker - 08-28-2018, 10:05 PM
RE: Ron's RCA 6T2 Restoration - by thirtiesradio - 08-28-2018, 10:25 PM
RE: Ron's RCA 6T2 Restoration - by Dan Walker - 08-29-2018, 09:29 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 08-29-2018, 09:02 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-01-2018, 02:34 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-01-2018, 05:21 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 09-01-2018, 05:46 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-02-2018, 04:26 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 09-02-2018, 07:14 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 09-02-2018, 07:49 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-03-2018, 11:59 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-03-2018, 01:10 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 09-03-2018, 02:27 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-03-2018, 04:28 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 09-03-2018, 05:07 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-03-2018, 05:25 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 09-03-2018, 06:33 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-03-2018, 06:55 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 09-03-2018, 06:57 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 09-04-2018, 03:20 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 09-04-2018, 05:48 PM
RE: Ron's RCA 6T2 Restoration - by Eliot Ness - 09-05-2018, 07:26 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-05-2018, 07:40 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-05-2018, 08:28 AM
RE: Ron's RCA 6T2 Restoration - by morzh - 09-05-2018, 09:06 AM
RE: Ron's RCA 6T2 Restoration - by Phlogiston - 09-05-2018, 10:36 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-11-2018, 07:10 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-11-2018, 07:14 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-15-2018, 09:11 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-16-2018, 04:03 PM
RE: Ron's RCA 6T2 Restoration - by PhilcoJohn - 09-16-2018, 04:36 PM
RE: Ron's RCA 6T2 Restoration - by Eliot Ness - 09-16-2018, 06:04 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-16-2018, 06:35 PM
RE: Ron's RCA 6T2 Restoration - by Eliot Ness - 09-16-2018, 07:16 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-16-2018, 08:21 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-17-2018, 08:35 PM
RE: Ron's RCA 6T2 Restoration - by Arran - 09-18-2018, 02:17 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-18-2018, 04:35 AM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 09-18-2018, 07:26 PM
RE: Ron's RCA 6T2 Restoration - by Eliot Ness - 09-18-2018, 07:39 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 09-18-2018, 07:53 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 10-27-2018, 04:52 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 10-27-2018, 05:13 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 10-28-2018, 07:33 PM
RE: Ron's RCA 6T2 Restoration - by morzh - 10-28-2018, 07:39 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 10-28-2018, 08:40 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-02-2018, 07:29 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-04-2018, 09:38 PM
RE: Ron's RCA 6T2 Restoration - by morzh - 11-04-2018, 10:37 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-11-2018, 08:51 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-24-2018, 06:20 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 11-24-2018, 06:40 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-24-2018, 06:57 PM
RE: Ron's RCA 6T2 Restoration - by Paul Philco322 - 11-24-2018, 07:46 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 11-25-2018, 01:56 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-25-2018, 02:08 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 11-25-2018, 09:10 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-27-2018, 10:19 PM
RE: Ron's RCA 6T2 Restoration - by morzh - 11-28-2018, 10:02 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-29-2018, 06:53 PM
RE: Ron's RCA 6T2 Restoration - by morzh - 11-29-2018, 10:41 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-07-2018, 08:07 PM
RE: Ron's RCA 6T2 Restoration - by morzh - 12-07-2018, 08:50 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-08-2018, 03:09 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 12-08-2018, 10:14 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-08-2018, 11:02 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 12-09-2018, 06:00 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 12-09-2018, 06:01 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-09-2018, 06:11 PM
RE: Ron's RCA 6T2 Restoration - by mikethedruid - 12-09-2018, 07:04 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-09-2018, 07:36 PM
RE: Ron's RCA 6T2 Restoration - by Arran - 12-10-2018, 02:26 AM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 12-11-2018, 08:02 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-11-2018, 08:16 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-22-2018, 09:42 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 12-23-2018, 08:22 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-23-2018, 09:19 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-23-2018, 09:24 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-23-2018, 09:25 AM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 12-23-2018, 03:54 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-23-2018, 04:19 PM
RE: Ron's RCA 6T2 Restoration - by EdHolland - 12-24-2018, 06:26 AM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-28-2018, 07:05 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-30-2018, 06:56 PM
RE: Ron's RCA 6T2 Restoration - by Greggshere - 12-30-2018, 08:22 PM
RE: Ron's RCA 6T2 Restoration - by Arran - 12-31-2018, 05:15 PM
RE: Ron's RCA 6T2 Restoration - by Steve Davis - 12-31-2018, 07:02 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 12-31-2018, 09:59 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 01-01-2019, 03:17 PM
RE: Ron's RCA 6T2 Restoration - by Ron Ramirez - 11-29-2019, 06:39 PM
