Ron's Cabinet Work for the 2018 Season
#53
Thanks Bob.
After two more coats of clear lacquer, the spots on the top still show. And I expected them to show as they are now depressed areas in the top. Not as much as shown above in post #51 (before I sprayed on an additional two coats of clear), but yes, they do show.
I may have to try painting on some clear lacquer in the low areas until I build them up slightly above the rest, let dry, then wet sand them flat. If I can pull this off, this should completely take care of the issue. I also have the little pressurized sprayer now from Home Depot into which I can put some lacquer thinner, if I need to.
RE: Ron's Cabinet Work for the 2018 Season - by Ron Ramirez - 09-15-2018, 09:24 PM
