A Philco 91 restore
It's covered in the Tech Section of the Phorum:
http://www.philcoradio.com/phorum/showth...?tid=14971
https://philcoradio.com/library/index.ph...18-others/
Icon_biggrin
Nathan had found a better type of cord within the past year or so. The source (Amazon) is mentioned in the link above.
A Philco 91 restore - by klondike98 - 01-10-2017, 01:36 PM
RE: A Philco 91 restore - by sam - 01-10-2017, 01:57 PM
RE: A Philco 91 restore - by morzh - 01-10-2017, 02:09 PM
RE: A Philco 91 restore - by klondike98 - 01-10-2017, 02:48 PM
RE: A Philco 91 restore - by morzh - 01-10-2017, 03:49 PM
RE: A Philco 91 restore - by Radioroslyn - 01-10-2017, 11:55 PM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 08:08 AM
RE: A Philco 91 restore - by morzh - 01-11-2017, 12:20 PM
RE: A Philco 91 restore - by Ron Ramirez - 01-11-2017, 12:21 PM
RE: A Philco 91 restore - by morzh - 01-11-2017, 12:25 PM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 04:55 PM
RE: A Philco 91 restore - by Nathan Slingerland - 01-11-2017, 05:14 PM
RE: A Philco 91 restore - by klondike98 - 01-11-2017, 05:16 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 12:11 PM
RE: A Philco 91 restore - by Ron Ramirez - 01-12-2017, 12:20 PM
RE: A Philco 91 restore - by Radioroslyn - 01-12-2017, 12:45 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 01:12 PM
RE: A Philco 91 restore - by Mondial - 01-12-2017, 05:18 PM
RE: A Philco 91 restore - by klondike98 - 01-12-2017, 07:42 PM
RE: A Philco 91 restore - by klondike98 - 11-13-2017, 04:09 PM
RE: A Philco 91 restore - by Steve Davis - 11-13-2017, 04:56 PM
RE: A Philco 91 restore - by Radioroslyn - 11-13-2017, 06:04 PM
RE: A Philco 91 restore - by klondike98 - 11-13-2017, 07:12 PM
RE: A Philco 91 restore - by klondike98 - 11-16-2017, 03:15 PM
RE: A Philco 91 restore - by klondike98 - 11-09-2018, 04:02 PM
RE: A Philco 91 restore - by klondike98 - 11-11-2018, 05:50 PM
RE: A Philco 91 restore - by Ron Ramirez - 11-11-2018, 11:23 PM
RE: A Philco 91 restore - by klondike98 - 11-12-2018, 07:35 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5387 online users. [Complete List]
» 1 Member(s) | 5386 Guest(s)
