09-05-2019, 09:03 PM
What I would do is measure the resistance across the two terminal on the cardboard tube.. If I'm correct you'll see a low value resistance there ( a few hundred to a thousand). So what you want to do is cut the wire that is soldered to the bracket and solder the new cap from the bracket and the other end of the cap to the terminal that is at the far end of the cardboard tube.
