Removing speakers
Thanks Mike !
  I got the 'rattle can' paint.   Icon_lol
Seller has shipped  the radio. I'm supposed to get it  Friday.
Removing speakers - by Jake Blake - 09-15-2019, 12:24 PM
RE: Removing speakers - by mikethedruid - 09-15-2019, 03:31 PM
RE: Removing speakers - by Jake Blake - 09-15-2019, 04:49 PM
RE: Removing speakers - by Jake Blake - 09-15-2019, 05:04 PM
RE: Removing speakers - by Jake Blake - 09-16-2019, 03:10 AM
RE: Removing speakers - by Jake Blake - 09-16-2019, 06:41 PM
RE: Removing speakers - by mikethedruid - 09-17-2019, 12:03 AM
RE: Removing speakers - by Jake Blake - 09-17-2019, 12:18 AM
RE: Removing speakers - by mikethedruid - 09-17-2019, 01:38 AM
RE: Removing speakers - by Jake Blake - 09-17-2019, 06:22 AM
RE: Removing speakers - by rfeenstra - 09-17-2019, 09:15 AM
RE: Removing speakers - by Jake Blake - 09-17-2019, 10:12 AM
RE: Removing speakers - by rfeenstra - 09-17-2019, 10:37 AM
RE: Removing speakers - by Jake Blake - 09-17-2019, 11:01 AM
RE: Removing speakers - by mikethedruid - 09-17-2019, 01:35 PM
RE: Removing speakers - by Jake Blake - 09-17-2019, 02:31 PM
RE: Removing speakers - by mikethedruid - 09-17-2019, 03:38 PM
RE: Removing speakers - by Jake Blake - 09-17-2019, 03:54 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4681 online users. [Complete List]
» 1 Member(s) | 4680 Guest(s)
