Not sure where to start
Pattern and color are what most folks try to match with the original cloths during restorations. Thick cloth can tend to muffle the sound but most of these sets are not exactly high fidelity. If that cloth has memories for you then by all means keep it.
Not sure where to start - by Mboaen05 - 12-05-2019, 09:24 PM
RE: Not sure where to start - by klondike98 - 12-05-2019, 10:31 PM
RE: Not sure where to start - by Mboaen05 - 12-05-2019, 11:55 PM
RE: Not sure where to start - by klondike98 - 12-06-2019, 10:48 AM
RE: Not sure where to start - by Mboaen05 - 12-06-2019, 11:04 AM
RE: Not sure where to start - by Mboaen05 - 12-06-2019, 11:05 AM
RE: Not sure where to start - by klondike98 - 12-06-2019, 11:31 AM
RE: Not sure where to start - by Mboaen05 - 12-06-2019, 12:03 PM
RE: Not sure where to start - by klondike98 - 12-06-2019, 01:17 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3889 online users. [Complete List]
» 1 Member(s) | 3888 Guest(s)
