Causes of static only coming out of 41-280 Philco radio
Jimy Wrote:What is the primary cause of "static only" coming out of 41-280 Philco radio? I cannot pick any station up, just the constant static hum?
Jimy
Hi JImy,
Is it static= crackling random noise ? Or a hum, like the constant hum from an aquarium air pump?
The hum would be from old filter capacitors, which as Ron asked about, should be changed. Please refrain from powering up the set again until at least those are replaced. A visual inspection should be done, just in case some of that rubber insulation fell off and the wires are touching underneath.
Please see:
http://www.philcoradio.com/tech/plugin.htm
Do you have experience in working with electronics? If so, you may be able to replace the capacitors yourself. Otherwise I'd suggest locating a person in your area, perhaps a vintage radio club that can help with thre electrical work.
Good luck.
Re: Causes of static only coming out of 41-280 Philco radio - by gary rabbitt - 01-22-2011, 02:44 AM
