Philco, 265 'Lyre' inquiry
My final word on the subject:
The ballast installation is a hack job done by an individual (amateur). No reputable manufacturer would mount a ballast in such a manner (sticking it where an electrolytic capacitor was intended to be clamped).
Philco, 265 'Lyre' inquiry - by claude.france - 02-29-2020, 03:34 PM
RE: Philco, 265 'Lyre' inquiry - by Radioroslyn - 02-29-2020, 08:40 PM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-01-2020, 06:06 AM
RE: Philco, 265 'Lyre' inquiry - by Ron Ramirez - 03-01-2020, 09:43 AM
RE: Philco, 265 'Lyre' inquiry - by Radioroslyn - 03-01-2020, 10:44 AM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-01-2020, 02:57 PM
RE: Philco, 265 'Lyre' inquiry - by Radioroslyn - 03-01-2020, 03:12 PM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-01-2020, 04:34 PM
RE: Philco, 265 'Lyre' inquiry - by rocketeer - 03-02-2020, 08:09 AM
RE: Philco, 265 'Lyre' inquiry - by Ron Ramirez - 03-02-2020, 07:31 PM
RE: Philco, 265 'Lyre' inquiry - by rocketeer - 03-02-2020, 10:29 PM
RE: Philco, 265 'Lyre' inquiry - by truePhilco - 03-02-2020, 10:55 PM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-03-2020, 03:26 AM
RE: Philco, 265 'Lyre' inquiry - by Ron Ramirez - 03-03-2020, 07:07 AM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-03-2020, 08:51 AM
RE: Philco, 265 'Lyre' inquiry - by rocketeer - 03-03-2020, 09:21 AM
RE: Philco, 265 'Lyre' inquiry - by claude.france - 03-03-2020, 09:33 AM
RE: Philco, 265 'Lyre' inquiry - by rocketeer - 03-03-2020, 11:08 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5284 online users. [Complete List]
» 2 Member(s) | 5282 Guest(s)
