03-12-2020, 06:14 AM
I realized the rings that I fashioned out of the remaining parts of the caps' cylinders did not center well on the contact ring on the chassis. so I removed them and ordered M22 copper rings with 28mm outer diameter which fit exactly right. After this the contact was good and the rings sit nicely. I cut a little groove for the negative wire soldered between the ring and the base to not skew the ring so it sits flat.
