Signal Generator Help
Quote:To do what you describe above, you don't really need a counter or any modifications. I am not advising against it. In fact, if you'll enjoy doing the mod's, then go for it, but .... more economically, to get your sig-gen frequency set all you need is a newer, digital radio to listen to the sig-gen. That will be as accurate as you'll need, given that your sig-gen will drift a little bit all the time that you are using it. For basic AM/SW radios it will be fine and even a little bit of drift will not materially affect your alignment work.
Well I would also be doing some work on AM/FM Radios as well as AM/FM Stereo Receivers. But for the most part most of the radios I work on are older AM/SW or AM only radios.
But this Signal Generator does have a Vernier Style Tuner which is a little bit easier to dial in than a Non-Vernier Tuner.
Signal Generator Help - by captainclock1988 - 04-16-2020, 06:53 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 06:56 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 07:20 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 07:44 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 08:27 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 08:50 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 09:14 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 09:43 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 09:50 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 10:08 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 10:24 PM
RE: Signal Generator Help - by captainclock1988 - 04-16-2020, 10:34 PM
RE: Signal Generator Help - by morzh - 04-16-2020, 10:51 PM
RE: Signal Generator Help - by 462ron - 04-17-2020, 07:01 AM
RE: Signal Generator Help - by Eliot Ness - 04-17-2020, 10:00 AM
RE: Signal Generator Help - by captainclock1988 - 04-17-2020, 06:44 PM
RE: Signal Generator Help - by captainclock1988 - 04-21-2020, 01:28 PM
RE: Signal Generator Help - by rfeenstra - 04-21-2020, 02:14 PM
RE: Signal Generator Help - by captainclock1988 - 04-21-2020, 06:45 PM
RE: Signal Generator Help - by 462ron - 04-22-2020, 06:53 AM
RE: Signal Generator Help - by captainclock1988 - 04-22-2020, 08:16 AM
RE: Signal Generator Help - by John Bartley - 04-22-2020, 10:10 AM
RE: Signal Generator Help - by captainclock1988 - 04-22-2020, 10:17 AM
RE: Signal Generator Help - by 462ron - 04-23-2020, 07:37 AM
RE: Signal Generator Help - by 462ron - 04-23-2020, 08:04 AM
RE: Signal Generator Help - by captainclock1988 - 04-23-2020, 11:08 AM
RE: Signal Generator Help - by captainclock1988 - 04-26-2020, 08:15 PM
RE: Signal Generator Help - by 462ron - 04-27-2020, 06:50 AM
RE: Signal Generator Help - by captainclock1988 - 04-27-2020, 03:18 PM
RE: Signal Generator Help - by captainclock1988 - 04-27-2020, 09:21 PM
