Mikes, Sams, and Terry's Cabinet restoration chronicles
He had, a few years ago, a step by step veneer chunk missing repair thread.
RE: Mikes, Sams, and Terry's Cabinet restoration chronicles - by morzh - 05-08-2020, 09:14 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3969 online users. [Complete List]
» 1 Member(s) | 3968 Guest(s)
