Philco mahagoney cabinet
Hi everyone, I've still been researching my Philco phonorama. I believe the model # is MODEL 22B4406. I've been saving my pictures on Flickr, tomorrow my husband is going to pull my cabinet out, so we can check it out better. It's pretty dusty, been sitting in our home for a good 35 years or more. Right now we are using it as a stand for our tv.
Philco mahagoney cabinet - by Papasphilco - 07-06-2020, 06:19 PM
RE: Philco mahagoney cabinet - by klondike98 - 07-13-2020, 11:38 AM
RE: Philco mahagoney cabinet - by Papasphilco - 07-13-2020, 11:22 PM
RE: Philco mahagoney cabinet - by klondike98 - 07-18-2020, 09:56 PM
RE: Philco mahagoney cabinet - by Papasphilco - 07-19-2020, 04:27 PM
RE: Philco mahagoney cabinet - by Papasphilco - 07-19-2020, 04:36 PM
RE: Philco mahagoney cabinet - by Papasphilco - 07-24-2020, 12:25 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3629 online users. [Complete List]
» 2 Member(s) | 3627 Guest(s)
