08-22-2020, 07:20 PM
You probably already found this PDF, but here is the actual Philco service information for your set. There is a basic restringing guide illustrated:
Unfortunately, as many of us have found, restringing a missing or broken dial is often trial and error. Mostly error. You're lucky to have found ANY re-stringing diagram, however vague it may be. Certain radio brands do have better guides than others but many (read most) have none at all. I have found some with the length of the cord laid out straight posted, but not often. I did the dial a few years back on my 40-180, but I neglected to document the path and length. Patience is a virtue, so if it gets frustrating, take a break and try it again some other time. Each time you try it (make sure you have a lot of extra cord on hand) you will get a little closer to the needed outcome. Good luck!
