EICO 235 VTVM
Hi, I am looking for some help on the R-23 when I try to do the calibration it says to adjust R-23 to zero the meter but R-23 does nothing. Where did you get with yours?
EICO 235 VTVM - by Bradley Rush - 12-23-2016, 12:35 PM
RE: EICO 235 VTVM - by Bradley Rush - 12-23-2016, 12:37 PM
RE: EICO 235 VTVM - by Bradley Rush - 12-23-2016, 12:38 PM
RE: EICO 235 VTVM - by Marko - 11-18-2020, 01:27 PM
RE: EICO 235 VTVM - by Radioroslyn - 11-18-2020, 02:17 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
