02-22-2021, 08:14 PM
Speaker was plugged in so that was easy. Found a loose wire and start to get B voltage readings. I attached the readings up to the 1st Det (tube 44) . Then a new problem the wire resistor (item 57) part # 6450 started to heat up and smoke. Unplugged and called it a night. So can you look at the attached reading a let me know what you think and what should a do with the wire resistor. Having a hard time giving up on this the cabinet restoration came out perfect just need the radio now
