04-22-2021, 10:55 AM
Dirk
If your speaker contains the transformer:
1. If you graft the transformer to the new speaker (the FC is OK, 10% difference is not very critical) it will result in 3 times the impedance and your output performance will be degraded quite a bit.
2. If however the speaker has its own transformer AND it was made to work with a 42 tube output (or a tube with the similar requirements for a load impedance) then the VC impedance no longer is important.
If your transformer is separate, then you are going to have same #1 problem. I think in the 45 it is separate and is installed on the chassis.
