Philco 37-650 Re-Re-Re Work
They should be. In a Bakelite block there is no reason not to use safety caps. In some radios restuffing an original tubular might prevent installing the safety caps which are mostly a disk. In this case try to use the highest AC voltage cap that will fit. Also adhere to the new standard for these - which I think is no larger than .01. I have seen some large values used - if you like a tingle when you touch your set. Icon_mad
P.S. Check for a bad or intermittent volume control. DO NOT clean it with D5 Deoxit. It will be destroyed. If you have to, use F5.
Philco 37-650 Re-Re-Re Work - by cknob - 12-07-2021, 10:34 AM
RE: Philco 37-650 Re-Re-Re Work - by Phlogiston - 12-07-2021, 11:30 AM
RE: Philco 37-650 Re-Re-Re Work - by morzh - 12-07-2021, 11:48 AM
RE: Philco 37-650 Re-Re-Re Work - by Mondial - 12-08-2021, 09:42 AM
RE: Philco 37-650 Re-Re-Re Work - by cknob - 12-12-2021, 04:57 PM
RE: Philco 37-650 Re-Re-Re Work - by TV MAN - 12-16-2021, 02:11 PM
RE: Philco 37-650 Re-Re-Re Work - by cknob - 12-16-2021, 02:56 PM
RE: Philco 37-650 Re-Re-Re Work - by Ron Ramirez - 12-16-2021, 02:58 PM
RE: Philco 37-650 Re-Re-Re Work - by Arran - 12-17-2021, 12:53 AM
