12-23-2021, 02:47 PM
What voltages do you have across the .1 cap you just put in? You should see about the same the voltage at the cosponsoring 26's plate. Unless your rf coil is rotting... It's important that the 100 ohm series resistor are good if not they will drop the hv going to each of the 26's
