01-06-2022, 02:22 PM
Well, got back on the radio and aligned and went thru the neutralizeing procedure to no avail. Did everything several times with no improvement. Went back to voltage checks and still low voltage on the 26 plates (52-55V), same reading across the 100ohm resistors. I was thinking the filter coil could be bad so checked the resistance in circuit it was 408ohms. I dont know where to turn, does anyone have the correct voltage measurement for points on the schematic such as F,G etc? What should I do now?
