01-29-2022, 10:24 AM
Create a loop antenna transmitter with a coil of about 5-6 turns of wire 4-6 inches in diameter and connect the hot side of your signal generator to one end. You now have a radio transmitter that varies the radio reception signal strength by how close it is to the receiver.
The second set of instructions can be used for the 40-195 alignment (note upper right corner).
