Philco Predicta board lifted trace and trace corrosion.
One of the best hand held desoldering tools is one of the Soldapullit (or something like that lol), it's a big blue solder sucker, and its kinda like holding a telephone pole to desolder, but it seems like it works a lot better than some of the smaller ones. A desoldering iron also works, but I dont think quite as well. Solderwick works great - IF you happen to get a good batch. I used the last of my Radio Shack supply, and the newer stuff is worthless. I noted as John mentioned there are a lot of cracked (cold) solder joints around the socket area. I too have fixed many a TV over the years by resoldering those, usually around heat producing components like power transistors, larger resistors, PC mounted flybacks, etc. You can bridge the bad traces with wire. May not be pretty but will work.
Tim
RE: Philco Predicta board lifted trace and trace corrosion. - by TV MAN - 04-17-2022, 09:31 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3357 online users. [Complete List]
» 2 Member(s) | 3355 Guest(s)
