06-26-2022, 03:01 PM
Going back over things I believe I made a few errors. When I measured item 48 that you mentioned, I actually measured item 58 which is the filter choke. The speaker should be a K6 but is a H12 with the output transformer p/n 2585 which goes to a K6. Anyway, it is open, but I did measure 3295 ohms on the voice coil after I unsoldered it from the trans. That will be another issue. On the good side, I replaced the 2 electrolytic caps with 8uF ones. I have to order the caps for the filter bank item 29, thought I had some but am short on the .25 caps. have a ,2 and a .22. Tubes should be here monday or tuesday.
George
George
