07-16-2022, 07:31 AM
Terry,
That is what I was referring to I rewound the coil at the top and hooked one side to the antenna/10k resistor and the other goes to item 6 and 3.
According to the schematic on service bulletin 129-B, there is another tap on the secondary that went to the on-off-freq. switch. That tap had the wire cut off. My radio did not have a three-position switch, just on-off.
Also found open primary on the det. coil item 12 which I will rewind later today. I have checked the osc coil and it seems to be good, and I am checking the 1st and 2nd IF. I think I need to get better at checking the whole radio before starting, instead of just jumping in.
I appreciate your help
George
George
