Custom printed circuit board?
+1 on all the comments.
Zenith advertised their chassis as hand built but the later ones had these conical metal connectors on phenolic strips mounted to the metal chassis/ these conical connectors also surrounded the tube sockets. these connectors were above the chassis and open underneath. The components were stuffed into these connectors, then the chassis likely went through a solder pool similar to the wave solder pool used on PC Boards, so slightly hand built. I went nuts trying to fix a zenith color set that "ghosted, toll I found the cold joint between one of these posts and a tab bent up from the chassis, that served as a ground. This was also a common issue on the PC Board solder points to the chassis tabs that supported them and served as chassis ground.
I Had several XL100 sets from that German store "Offen der Streit" that I fixed and gave away. (I think my youngest brother still has one). When I bought a nice RCA Demensia (never bought the companion HiFi components), they went to single PCB, likely for 3 reasons:
1. It was cheaper.
2. Yes, solid state devices were proven to be more reliable.
3. Most of all, too many intermittent connections from the plug-in boards!
Custom printed circuit board? - by RetroRev - 10-02-2022, 10:07 PM
RE: Custom printed circuit board? - by MrFixr55 - 10-03-2022, 07:16 AM
RE: Custom printed circuit board? - by morzh - 10-03-2022, 09:21 AM
RE: Custom printed circuit board? - by Chas - 10-03-2022, 09:36 AM
RE: Custom printed circuit board? - by RodB - 10-03-2022, 09:49 AM
RE: Custom printed circuit board? - by RetroRev - 10-03-2022, 11:35 AM
462ron - by 462ron - 10-04-2022, 08:13 AM
RE: Custom printed circuit board? - by radiorich - 10-04-2022, 08:17 AM
462ron - by 462ron - 10-04-2022, 08:25 AM
RE: Custom printed circuit board? - by MrFixr55 - 10-04-2022, 07:13 PM
RE: Custom printed circuit board? - by radiorich - 10-04-2022, 07:30 PM
RE: Custom printed circuit board? - by falcon123 - 10-07-2022, 04:35 AM
RE: Custom printed circuit board? - by RodB - 10-07-2022, 08:16 AM
RE: Custom printed circuit board? - by falcon123 - 10-07-2022, 11:03 PM
RE: Custom printed circuit board? - by MrFixr55 - 10-08-2022, 12:34 AM
RE: Custom printed circuit board? - by morzh - 10-08-2022, 11:23 AM
RE: Custom printed circuit board? - by MrFixr55 - 10-09-2022, 08:09 AM
RE: Custom printed circuit board? - by morzh - 10-09-2022, 12:55 PM
RE: Custom printed circuit board? - by morzh - 10-09-2022, 04:23 PM
RE: Custom printed circuit board? - by Arran - 10-20-2022, 03:02 AM
