Philco 40-180 Compensator Alignment
>Around 1232 tube, measured 182V (160V schematic) and 179V (105V schematic).
Ok Those are a bit high. The 182v tell us that #13 is working. If it wasn't you would have 0 volts there. Having both the plate & screen grid voltages high means that the tube isn't drawing much of any current. So need to look at #7 the 390 ohm resistor. Also check the ground connection. They can get oxidized a not make a complete connection. The pins on the loctal tubes oxidized and can make poor connection. Or could be a weak tube.
So folks don't care to work on the '39-'42 Philco as that use rubber coated wire (US sets) and Loctal tubes.
Philco 40-180 Compensator Alignment - by tludka - 03-16-2022, 07:31 PM
RE: Philco 40-180 Compensator Alignment - by Radioroslyn - 10-25-2022, 07:06 PM
RE: Philco 40-180 Compensator Alignment - by RodB - 10-28-2022, 09:12 AM
RE: Philco 40-180 Compensator Alignment - by RodB - 10-28-2022, 08:32 PM
462ron - by 462ron - 10-29-2022, 07:11 AM
