01-17-2023, 09:10 AM
Thanks for the advice. I use an isolation transformer to a variac to a dim bulb tester. I have also rewired the power with a fuse and the return wired to the switch. I prefer to be safe than sorry. I'll check those voltages you listed. Currently, I have no negative voltage on pin 5 of the 12SA7 tube. I need to find out where that is going. I'll try some deoxit on the variable capacitor as all of the rotors look to be straight. I told myself I wanted to learn when I started this adventure. I will get this working.
Bob
Bob
