Have had this television since I was 12 what model is it?
#38
Thank you both. I will look at the neck today to check for any numbers. Appreciate all the help guys!
RE: Have had this television since I was 12 what model is it? - by Brian joy - 01-29-2023, 09:56 AM
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3546 online users. [Complete List]
» 2 Member(s) | 3544 Guest(s)
