Have had this television since I was 12 what model is it?
#39
Hi Brian. In looking a little further in that website I gave you I noticed there was a pdf of Cisin's Tube Substitution Guide for 1959. Your tube is located in Group 28. In your photograph I can't tell for sure but it appears spherical with an external tube coating. If that's the case then your tube could be a 21EP4A or 21EP4B. When you check the neck for any markings, also check the broken base... it might have been printed there. Take care and BE HEALTHY! Gary
RE: Have had this television since I was 12 what model is it? - by GarySP - 01-29-2023, 03:39 PM
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3424 online users. [Complete List]
» 2 Member(s) | 3422 Guest(s)
