Have had this television since I was 12 what model is it?
#43
Check post 14.  [Image: https://philcoradio.com/phorum/images/sm...humbup.gif]
RE: Have had this television since I was 12 what model is it? - by Radioroslyn - 01-30-2023, 09:16 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3891 online users. [Complete List]
» 1 Member(s) | 3890 Guest(s)
