Philco 46-431
Thanks
I generally rebuild the entire power supply on a radio in this shape replacing all the resistors and caps.  I definately won't plug it in until things are rebuilt and checked out.
I suspect this radio will need lots of replacement capacitors from the looks of the ones in it.
This radio has a combo dual .01uF  capacitor/terminal strip for the incoming AC line. I'll probably remove it and replace the capacitors on a terminal strip, unless I am told this is a bad idea or someone has a better idea.
If the power supply dual electrolytic cap is easily removed, I'll probably gut it and stuff it with new caps. Replacement caps will be much smaller. I may increase the value of these if the rectifier tube can stand the increase. I haven't looked at the tube  data yet.
Pat
Philco 46-431 - by pbunn - 01-31-2024, 04:18 PM
RE: Philco 46-431 - by RodB - 01-31-2024, 04:48 PM
RE: Philco 46-431 - by pbunn - 01-31-2024, 05:05 PM
RE: Philco 46-431 - by RodB - 01-31-2024, 09:02 PM
RE: Philco 46-431 - by radiorich - 01-31-2024, 09:23 PM
RE: Philco 46-431 - by pbunn - 02-05-2024, 11:28 AM
RE: Philco 46-431 - by RodB - 02-05-2024, 04:13 PM
