Meet Phrank, my Phranken-Philco 116X
Hello volkswagenman66 ,
nice Console !
RE: My Phranken-Philco 116X - by klondike98 - 02-05-2024, 01:56 PM
RE: My Phranken-Philco 116X - by morzh - 02-05-2024, 04:14 PM
RE: My Phranken-Philco 116X - by RodB - 02-05-2024, 04:26 PM
RE: My Phranken-Philco 116X - by morzh - 02-05-2024, 04:42 PM
RE: My Phranken-Philco 116X - by volkswagenman66 - 02-05-2024, 06:48 PM
RE: My Phranken-Philco 116X - by morzh - 02-05-2024, 06:52 PM
RE: My Phranken-Philco 116X - by volkswagenman66 - 02-05-2024, 06:53 PM
RE: My Phranken-Philco 116X - by volkswagenman66 - 02-05-2024, 06:57 PM
RE: My Phranken-Philco 116X - by morzh - 02-05-2024, 07:26 PM
RE: My Phranken-Philco 116X - by radiorich - 02-06-2024, 08:27 AM
RE: My Phranken-Philco 116X - by Radioroslyn - 02-06-2024, 07:15 PM
RE: My Phranken-Philco 116X - by volkswagenman66 - 02-06-2024, 08:11 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 1933 online users. [Complete List]
» 3 Member(s) | 1930 Guest(s)
