03-19-2024, 12:56 PM
I also found that the #12 padder has a wire that goes to the band switch, which when the switch is put in the SW band position the lead coming from the #12 padder mates with the 4100pf cap. which goes to ground. The band switch wire is connected to the same terminal as the lead that goes to the osc coil on the padder. The 4100pf cap was put in there to replace the trimmer #11.
Jim
Spring Lake MI
