Philco 39-7C Restore
Bob, yeah. The secondary is critical, as it is part of the tuning.
Is it a simple bobbin, easy to rewind, or one of those "cross-wound" wax-dipped jobs?
Philco 39-7C Restore - by klondike98 - 04-15-2024, 07:30 PM
RE: Philco 39-7C Restore - by Paul Philco322 - 04-15-2024, 07:32 PM
RE: Philco 39-7C Restore - by morzh - 04-15-2024, 08:27 PM
RE: Philco 39-7C Restore - by klondike98 - 04-16-2024, 02:04 AM
RE: Philco 39-7C Restore - by morzh - 04-16-2024, 08:48 PM
RE: Philco 39-7C Restore - by klondike98 - 04-16-2024, 10:02 PM
RE: Philco 39-7C Restore - by klondike98 - 04-17-2024, 12:53 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5235 online users. [Complete List]
» 1 Member(s) | 5234 Guest(s)
